Group: DynoMotion Message: 6352 From: maba_sweden Date: 12/30/2012
Subject: Encoder wiring Leine Linde Combimill
Hi
Just wanted to double check my wiring with you before Its to late :-)
Im replacing my old Siemens Sinumeric 3M with Kanalog and KFlop control boards on my Storebro Combimill from ~1985
My encoders are Leine Linde Optical Incremetal Encoders
5V 1250 pulses/rev
They have (8) wires and this is how I plan to wire them:
(A+) JP1 CHA_DIFFPLUS_0
(A-) JP1 CHA_DIFFMINUS_0
(B+) JP1 CHB_DIFFPLUS_0
(B-) JP1 CHB_DIFFMINUS_0
(Z+) Should these be connected?
(Z-) Should these be connected?
(+5V) JP8 +5V
(GND) JP6 GND
Will I need any resistors for the encoder inputs?
Heres a link to the Combimill wiring diagram
http://maba.unx.se/cnc/Xaxle.jpg
Later I will wire the ±10V to my servos through
(pin 12) JP11 DAC_10V
(pin 13) JP11 GND
Does this seems ok?
Regards Mattias
Group: DynoMotion Message: 6355 From: Tom Kerekes Date: 12/30/2012
Subject: Re: Encoder wiring Leine Linde Combimill
Hi Mattias,
That all looks correct to me.
You shouldn't normally need any resistors on the encoder inputs.  Kanalog has 470 ohms internally across the + and - inputs which is usually enough.
The Z inputs are not required.  Sometimes they are used for more accurate homing.  If you wish to connect them they may be connected to any spare differential input.
